North42g
Got a '98 Ford Ranger 3.0L ; 4 x 4 ; 4WABS ; 243,007 Miles.
Recently I've noticed that when coming to a stop, at low speeds, the rear end locks up on me. It doesn't happen every time. It feels like the Brake Pedal is overly sensitive. I have a SOLUS-PRO scan tool that I use at work. I scanned the ABS System for codes and found none. In fact, all sensors seem to be operating normally. I wonder if it has anything to do with the Parking Brake assembly? I say this because one time after the pedal was depressed, it would not release. I had to get under there and jiggle the Parking Brake cable until the the right rear wheel finally came loose.
So I am not sure if the problem is Electrical ABS Sensor related or Mechanical related.
Like I a fore mentioned,when this happens, the rear brakes feel very sensitive. I want to solve this issue right away because I'm afraid that when I driving down the high-way @ 75mph and had to hit the brakes, my rear end would lock-up and I 'd loose control of the Truck!! Especially if my wife or Father was driving it!
I hope some one has seen this issue before and can help me. Thank You in Advance!
