Rear sway bar?
Yes, a Bronco 2 rear bar will fit with out modification
I have a bronco 2 rear bar, it bolts right on, even has holes in the frame already.
You'll also be able to find those sway bars on rangers from the 90's. My ranger came with the "handling package", which meant front and rear bars. Many others came with both bars, too.
Damn DangerRanger93... I'm jealous of that perfect yard you have.
Hey man thanks for the reply,and picture,but what year bronco,and also i found this [/PHP]http://www.andysautosport.com/ford/1998_2000_ranger/suspension/sway_bars/belltech/ would these work?
Here is the rear swaybar on my Ranger. The swaybar came off a Ranger Splash
You'll just have to check around the junkyards. Came on many different years, and within the years some had them some didn't. They also came in up to a 1 inch diameter.
What do you mean by "would these work?" You have a 2000 ranger so they would fit. That set would probably work great if you were planning to upgrade both of them. For just the rear it will work but you need to be careful and make sure it is smaller than the front. That said a used bar from the junkyard work just as well if you were only looking to add a rear bar. That BellTech bar is 177 + shipping while a used bar would probably be 70 or less from a local junkyard.
Thanks Josh T but I was thinking of upgrading the front also,and for the used junkyard sway bars,I live in Louisiana and everything in the junkyards here are junk
not sure what year mine is off of, but the front of the truck was the same as 89-92 rangers, so whatever years that would be.
and insanejughead, looks can be deceiving haha
