Rear spring spacers
Redneck Youth
im taking some measurments to see what coil spacers i should get, and my measurments are coming up to about a 4 inch difference from front to back, i know that my front body mounts are shot, so im losing about an inch (?) there... but that still leaves me 3 inches difference... im wondeirng if the spring spacers that the 4x4's have in the back has anything to do with what spacers i should get... :icon_confused:
i accidentally posted this one twice, it doesnt matter which one you comment on, but probably do the one with more replies...
You can add a lift block at the rear. I would not got over 2 inches on a block. If you can put on newer leaf springs it would be much better and would give some lift..Exoploder leafs work great. Go to the scrapyard and see what you find. What body mounts on the front are you talking about? Cab mounts? Ball joints? What front suspension do you have? Coils springs can be swapped out for taller coils and they do not cost much. They will last longer then using a spacer. Check Ebay for your year truck and see what you find.
my truck in the back has factory spacers under the springs, and i was referring to the body mounts in front... and yeah ill get to the yard and look for some stuff
