Rear shocks
cubewhiz
Kearny, NJ
2.9 V6
1"
31x10.5R15
My shocks are pretty much shot now and I just installed Explorer springs in the rear (and I'll be installing some leveling coils in the front soon).
Does anybody make a good shock that is about 2" longer than stock?
I noticed there are Bilstein shocks for 0" lift and then it jumps to 4"...nothing in between?
I guess I'd be better off with the 0" lift since my lift is only about 2"
If you go Bilstien and want 5100s go to the shockwarehouse.com, you'll have to measure for which shocks to order though.
The factory replacement shocks will work fine for the rear. The front might need longer depending upon the shock manufacturer, spring used, vehicle, etc.
