so how do i tell if its the main seal by cleaning the drivers side? wont it leak down through the bell housing then out the bottom?? im lost
I thought you had the 2.3 but I think you have the 3.0?
The oil pressure sensor will sometimes leak and it's on the drivers side of the engine (may still be on your engine too), so I figured if you sprayed that side of the engine well you would be better able to MAKE SURE it was the rear main. Sometimes a leak there will appear to be a rear main seal leak.
I would hate for it to not be a RMS leak and you go through all that labor is all.
Allen
