Rear main seal...sleeve
vbrad511
Springfield, Illinois
I'm in the midst of putting the clutch in my 97, 4.0. I bought a rear main from Felpro that came with a sleeve. There was not a mark on the crank. Is it ok to just install this seal and forgo the sleeve? It did try to put it on, just for the sake of doing so, but it sure didn't want to go, so...
Speedy sleeves are usually a real pita to install. A bearing press or installer of some sort makes it alot easier. Not really sure if you could put the seal in without the sleeve. The seals are mostly made oversized to accommodate the thickness of the sleeve. That being said, is your seal supposed to be stock size? Or is it one designed for a crank with a groove in it where you need the sleeve?
Sent from my ASUS_P00J using Tapatalk
I honestly don't know the sizing. The sleeve came with the seal. I watched a youtube video yesterday where a guy made a driver out of a pvc coupling. I did that, and cleaned the surface up, but even with the driver it just wouldn't start on the crank. I have installed the new seal now, seemed to in ok with the driver, but if it's designed for a larger surface, as-in the sleeve, I didn't want to finish putting it back together just to find out the seal was wrong and it's leaking.
I agree. Best I can say is verify with either the parts store or manufacturer as to weather the sleeve is required or not.
Update...I just talked to a buddy who worked for a bearing and seal dealer. He's comfortable that I'll be just fine without the sleeve. I'm going to put it back together the rest of the way tomorrow and see how it does.
Thanks
