Rear main seal an oil pressure sender switch 2.3
The Toolman
Lake of The Ozarks Warsaw, Mo.
99 Ranger Auto
1994 ranger xlt 2 dr 4 cyl 2.3 5 spd 2 wheel drive
Got an oil leak that needs fixed and I am sure it is one of these 2. Front seal is fine an valve cover is dry all around
1.Can you change the rear main without taking the pan an main cap off? i.e. is it a one piece that you can replace by removing the flywheel an popping it out an back in?
2. Where is the oil pressure sending switch/unit an my 2.3 engine, and is it easy to get to an change?
Thanx guys
Ron B.
