Ok I tried doing a search & search does loading process then freezes tried it several times.
I have a 94 long bed with a 2003 bed on it & noticed that the inside of the bed has the angled area to the rear section of the bed like the freont has for the filler hose clearance.
Did any 93+ rangers come with rear fuel tanks? Im getting a spare bed to use as a project as I want to do a DODGE thing to my bed.
Built in storage areas on both sides.
The bed will be cut up for extra build material as I want to also make the storage area extend inward even with the vertical inside lip of the bed rails & also was planning on doing a rear fuel tank as well & using the fuel door & surrounding area to graph into my bed.
While im at it I also want to make the center non existing bed pocket a an actual bed pocket & replace the front bed panel as mine is damaged.
Bed im getting is a short bed but all of what I need is in good shape even though the the bed is damaged & a plus is that it has factory flares so I can measure the attaching holes to drill pattern into my bed to attach my EDGE flares.
Plus for the cost I cant go bad @ $30 ,after all after im done doing surgery on it i'll probably be able to get the money back from scrape yard.
FREEBIE project. Some what.
Seen people using Bronco IIs & also Cherokee tanks for rear. Any info as to size of tanks as far as Gallons & also measurements.
I want to be able to have lockable storage boxes on both sides & weather tite
