atvkid4eva
well i had explorer springs on it prior to the chevy's and the lean was still in that side.
Simple test would be to swap the springs from side to side to see if the lean follows the spring that would eliminate out a weak spring pack.
okay well i removed both rear leafs and the lean is definetly in the frame rails. How can i fix this? i was thinking jack it up till its level and welding some 4" channel in there...i also removed the previous owners attempt of a cross member. Junkie- Is there any hope on straightening it? See pic. The pic has NO leafs or shocks installed
My '93 2wd longbed has that exact same lean. It sets at stock height and has had all four springs replaced. I wonder if mine gained the twist when the original left rear, rear spring hanger broke at the frame. Any thoughts?
UPDATE: I bought a set of screw in boosters (temporary) for the front left coil. It brought the rear-right corner right back down where it should be. Should be ok for a while, atleast until I can get the battery moved to the opposite side and the new lowering coils and 4" rear flip installed.
