rear end noise?
  • Thread starter Thread starter irishblessing
  • Start date Start date
irishblessing
Guest
where my tires mount to my axles i have about an inch of play where i can pull on my
tires and they slide out about an inch when i pull on the wheels or when im drving around
corners i can hear it move out then back it sounds like a either a thud or chirping is this
normal? if not how can i fix it?
If you have a limited slip, the clutches are most likely worn with a lot of free space in them.
My old B2 with a few hundred thousand on it did the same thing, new clutches straightened it right out. Had to change them out a couple times with the B2, I also changed the axle bearings last time I had them out. Looked and felt good, but I was driving over a thousand miles a week at the time and didn't want to take a chance.
If it's open I'm not sure.
Ken.
