joey74
Two questions would a 1994 rear end from Ltd work in a ranger? What rear end do they have and would they have disk brakes? Thanks joey!
If it is old enough to be an LTD not a crown vic then it is likely a 9" I think, rusty might know he used to have one or was that an LTD II?
Well the last generation of a regular LTD was something akin to a long nose RWD Tempo. It was also using the 8.8.
The last generation of the Crown Vic LTD that used the 8.8 as well.
I don't know when these cars stopped using the 9", but it was before 86.
will the disk brakes work on a explorer rear end? Thanks joey!Well the last generation of a regular LTD was something akin to a long nose RWD Tempo. It was also using the 8.8.
Why not use Explorer disc brakes for an Explorer rear end?
Second, how did you bend a front TTB axle hitting a deer? I ran my passenger front tire directly into a log that was sitting in a ditch lengthwise (in snow) at ~20mph and didn't bend anything but the radius arm crossmember and the radius arm thrust washer...
I finally found a brand new L/S TTB. A member of The Ranger Station had it and only charged me $75 plus Shipping. Thank you for your help !I hit a deer last year and just found out it bent the left TTB. I would like to know if a TTB from an 87 Bronco II will fit my truck ?
