Rear disk Q...
grumpyguy
Pitt Meadows B.C. Canada
Is it really necessary to run the backing plate/dust shield? Brakes in question are a Crown Vic set for my Ranger. It will be using the parking brake as well. Thanks.
If I'm not mistaken, the parking brake assy and the backing plate are one...
SVT
The crown vic dust shield protects the parking brake only.
The large flimsy sheet metal shield on the explorer brakes it best at holding gravel IN against the rotors than keeping shit away.
I jokingly refer to the Crown Vic dustshields as "bikini" dust shields.
AD
Request>>>
Could you start a thread with pics on this swap PLEASE?
I have thought bout the CrownVic swap on my 92 Explorer axle, as the X-cop car CrownVics are plentiful around here......:icon_idea::icon_thumby:
THANKS!!!
THANKS!!!
You do know that since you have an exp axle, that the disc brakes from a 95+ exp axle is direct bolt in swap minus your master cylinder...
SVT
Uh huh............
You do know that since you have an exp axle, that the disc brakes from a 95+ exp axle is direct bolt in swap minus your master cylinder...SVT
YES, I know this as I have a 98 Explorer disc brake rearend under my green 94.........but as I said, X-cop car CrownVics are plentiful around here & WHOLE LOT CHEAPER to buy there parts.:beer:
