Find out if they did a "static" or "dynamic" balance.so i had the tires rotated and balanced few days ago. Starting to think this vibration is coming from the wheels. Truck seems to vibrate at all speeds now more so at 45mph seems to be smoother at 60 and above. thinking maybe a bad job on the balancing? i did grab hold of the ujoints in the front axle. center ujoint does have some play not sure if it would cause such a vibration but i suppose its possible
I worked at tire shop one college summer. I remember the balancer you could set to static or dynamic...and that would balance it based on weight being only on the inside of the wheel or both...or you could set it to dynamic with was tell me where the weight needs to go and how much.
From there weight installation also mattered. The heavier ones can get pretty long and centering em up nice matter...grease monkeys just hammer em in ballpark location, then it calls for more weight, then they half aimed hammer in more...so on and so forth..next thing you know it's caked in weights.
Some wheels only allow weights on the inside, or just to maintain look of fancy wheels, guys will demand that.
Just like most things, it's not rocket science, yet lack of attention to details will bone you.
Yep sound right...Get it patched/plugged whatever...I still plug my own tires lol...thank you for the info, well i checked my wheels and theres weight both on inside and inside so im assuming they did dynamic balancing? i did find a nail in my tire last night when i was looking at my wheels so i made an appointment to get tires rechecked and nail removed and repaired.
It didnt vibrate when it rolled off the lot 30 years ago.well got my tire fixed and rebalanced. there is a huge improvement but still has some vibration. Think im gonna have to live with it as this truck is over 30 years old. May look into changing ujoints on the front axle next time i do brakes and rotors. May also change ujoints in the driveshafts since its pretty easy and cheap job to do.
thank you all for your suggestions. If i ever find the culprit ill be sure to give an update
No reason to live with something it shouldnt do![]()
i agree but after all the parts, money and time ive put into this i dont really know what else to do? ive done just about everything i can think of to find and eliminate this vibration and havent been succesful
