Readylift 2-Inch Leveling & 3-Inch Lift Kits
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
26306
ReadyLift 2-Inch Leveling Kit:
For the Ranger owner who just wants to remove some of the exaggerated rake these trucks have from the factory, our new CNC-machined billet Aluminum 66-2920 2.0" front leveling kit is perfect to help get the Ranger closer to level while allowing for an mild increase in tire size. This kit is incredibly easy to install and features our time-tested top/bottom strut mount spacers. Requires no cutting or modifications and installs easily in just a few hours.
Kit includes 2 top and 2 lower strut extension spacers.
The ideal choice for Ranger owners who want to raise the front of their new truck but want to retain some of the factory rake.
Allows for 18x9 +18 or +30 offset 265/65R18 or 20x9 +18 or +30 offset 275/55R20
Want a taller front lift? Please check out 69-2930 and 66-2930 3" kits.
ReadyLift 3-Inch Leveling Kit:
ReadyLIFT is proud to offer 2019 Ford Ranger owners a premium quality front leveling kit to help remove some of the exaggerated rake these trucks have from the factory. The ReadyLIFT new CNC-machined billet Aluminum 66-2930 3.0" front leveling kit is perfect to help get the Ranger level and looking much better while allowing for a mild increase in tire size. This kit is easy to install but does require a spring compressor. This kit uses our Top Hat Replacement technology that combines a top mount leveling kit with a spring preload spacer in one single component. Requires no cutting or modifications and installs easily in just a few hours.
The ideal choice for Ranger owners who want to raise the front of their new truck and install larger wheels and tires, all while maintaining the factory ride and handling.
Allows for:
18x9 +18 offset 265/65R18
18x9 +30 offset 265/65R18
20x9 +18 offset 275/55R20
20x9 +30 offset 275/55R20
Note: the front crash bars can be loosened and adjusted forward to increase clearance.
Want front and rear lift? Please check out 69-2930.
Ready Lift 3-Inch Lift Kit:
ReadyLIFT is proud to offer 2019 Ford Ranger owners a premium quality suspension choice. We combined our 3.0" front leveling kit with a 1" tall rear block for lifted stance both front and rear that provides a small amount of rake for towing or hauling. The ReadyLIFT new CNC-machined billet Aluminum 69-2930 3.0" front kit is perfect to help get the Ranger level and looking much better while a heavy-duty 1" tall rear block complete with centering pins and longer u-bolts brings the rear up nicely. This kit allows for a mild increase in tire size. 69-2930 is easy to install but does require a spring compressor. This kit uses our Top Hat Replacement technology that combines a top mount leveling kit with a spring preload spacer in one single component. Requires no cutting or modifications and installs easily in just a few hours.
Allows for:
Video:
Link:
https://www.readylift.com/shop/v/ford/ranger/2019
