RC 6 inch
mazda96
Quebec,Canada
hi I have a 96 b2300. i'm looking to build my truck to be able to catch air with it. will the rought contry 6 inch lift would be good? If not any one have any 7s kind of set up???
tanks
stay away from rough country. Look into threat, autofab, giant, or camburg.
I'm on a real tight budget and the only lift that I find in classifieds is the rought contry 6 inch. I also wonders how does 7s truck can handle that much lift on stock beam and location.
thanks
Just lifting a truck does not make it handle jumps better, and if it's a cheap lift, it'll make it worse than stock for jumping/durability.
u dont want lift u want wheel travel is it 2 wd or 4 wd
my truck is 2wd. I'm still wondering how a 7s truck with stock beam and stock location can have that much travel. Any help??
why im a asking this is becose my truck needs new coil and I was thinking about to do the f-250 shock tower mod but I'm wondering what coil wou you sugest me, if I keep my stock beam/raduis arms and stock location, to get the maximum travel .
Thanks
the camburg 5.5 is the best budget kit out there. it has what you need. RC is not someone i would go with to do any type of jumps.
As true is this may be. How is he supposed to put the kit on his truck? He has beams. The kit you mentioned is for a-arms. This is why I am thinking threat would be his best bet.
:icon_thumby:
I had idea for my truck tell me what tou think about it. Some bilstein 5150 mounted on some custom shock mount. but im still wondering wich coil tu use. any sugsestion?
