Rate my old engine setup
94 351 roller engine, torker carb intake, 750 holley dp converted to blow thru. mp gt45 turbo feeding it.
Heres last pic I took, which was a few months ago. It has been started since then with no turbo. Can't wait to get it on the road with this setup.
Looks like it should be alot of fun.
I see that in your video you have 99 and newer Mustang 17" wheels. My question is how did you get the front center caps to fit on the wheel with the Ranger rotors?
Well, As for the wheels I think I ran a 1/4'' spacer and also took the dust cap off of the spindle and theres at least 1/8'' that can be taken off the end of the spindle. I just cut off the most I could and not cut through where the cotter pin goes.put the dust cap back on and tap it with a hammer it will flatten alot. Also shaved some off the inside of the center cap. Its sounds like alot to do. but probably took 45min to hour to do both wheels.
well,finally got it off jackstands and got to pull it out of the garage on its own power. still have a few things to redo the cold side pipe and the radiator hose was rigged up so I could pull it outside. few pics below and turbo spooling sounds great can't wait to get it on the road. burnout vids will be on youtube very soon.
[/URL] Uploaded with ImageShack.us[/IMG]
