RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
- Mar 15, 2009
- Automatic
Well, I finally decided to do the rear brakes on my dually yesterday after it kept taking longer and longer to stop, and with little to no parking brake grabbing. Well, I knew one side the shoes would be wet, I had to change a wheel cylinder a couple of weeks ago, I bought 2 to do both sides, but never did the other side, and I didn't have enough $$ to change the brakes at that time...Here is what the shoes looked like...
And this is the other side, this explains why the parking brake wasn't grabbing...Good thing I bought both wheel cylinders!!
Sooo after I pulled everything apart, and got the glaze off the drums and cleaned up...
I started to put everything back together, and then I realized I got the wrong brake shoes, I got the shoes for a single rear wheel, not a dually...so I put the order in for the correct shoes (called mom while she was in town)...Well I went back to install the wheel cylinder on the passenger side...
and that's when I noticed this...
Soooo back to order more parts before the delivery driver leaves town...but before I get the hub pulled I removed the axle and the splines are covered in a brown milky fluid...Yep, just my luck, I got contaminants in my diff and now have to flush it...Here is what it looked like coming out of the cover...
Pics of the internals...
Not supposed to look like this, is it
Now, if this wasn't bad enough....The first place I ordered the parts from showed they had it in stock, but when the delivery driver aka my mom got there, they just sold it, they got so busy they forgot to pull the seal off the shelf...so after cancelling my order and crediting my card, I ordered from another store online, and off the delivery driver went. Then called the store and verified...Well, they had their hands on the seal, but they were having problems with the computers and getting the order printed out...They ended up cancelling that order and crediting my card again
Then they took the card over the phone and got everything taken care of just as the delivery driver was pulling up...Well, after all this I got it back together, adjusted the brake shoes, I still dont have good brakes...so I'm thinkin i need drums, but before I spend $$ on new drums, I think I'm just going to upgrade to rear disc brakes....Wait til you see what I have in store for this!! I started about 830am and I finally got finished around 7pm...Talk about a rough day doing brakes!!
SVT
SVT
