Oh god not more big lights....
oh yeah.
the alignment was about normal price wise...but i would bet discussing ahead of time the fact it was all lubed and loose would have kept the bill down to 120 or so.
as to your mpg's...did you calibrate the speedo before and after the gear swap so you knew what the real mpg was?
Oh! I DID discuss with them that I had that suspension apart within the past week, and that everything should be easy to get to.
It's the fact that I was very SPECIFIC about what kind of suspension that I had, what truck, and what was involved with aligning it. What they told me, is that it'd be the price of the alignment ($70), and the price of the alignment bushings. So the fact that they inflated the alignment bushings from 11.49, and 13.59 to $24 and $25, then charged me an hour labor rate to install them. Then held my truck in the bay........they knew they were bending me over and hoping I wouldn't know any better. Btw, after talking. This shop already has a bad reputation of screwing people over.
Thanks to 2 years of an automotive program(almost wrapping up an associates) and an Ford MLR cert under my belt, I know what's involved and know what I'm talking about.
But you're right bobbywalter, it only should have been $110-120. NOT $190ish.
With the speedo...... I think the 3.73 gear is about right, I may need to change it though. Also, when I passed a radar/sign thingy, you know "you speed is", it read me at 70mph, and I was maybe a .5mph under that. BUT, if I'm doing the math correctly, 3.73's and 235's are about the same as 4.10's and 31's.......by that note, I notice my gas disappearing ALOT less faster. 5-8 mpg is noticeable.
