Ranger with 4 inch backspaced wheels
Stinker12100
Columbus, NE
Im looking for a picture from the side of a truck with wheels with 4 inch backspacing. Im buying some new wheels and i wanna see how far they would stick out of the wheel well. The size wheels im getting are 15x8 with 31x10.5 r15 tires on them. Any help is much appreciated.
Just from doing the math, the difference between your, assumed stock, wheels is one inch width and a half inch of backspacing. Guessing that there's an additional half inch of width on each side in comparison to the 15x7's, your wheels will be 1" farther out than your current setup. 1/2" at a minimum, and 1.5" at most.
4" bs, 10.50 wide
Just remember that running the incorrect bs on a set of wheels can cause damage to suspenstion parts. Make sure nothing rubs or grinds anywhere. I have seen many people who put on incorrect wheels and had major issues. Just be safe, Bro!!
Ya i e checked with other people who have wheels with 4 inch backspacing and no spacers. None of them have had problems so i should be fine. Thanks for the concern though
no spacers. my back axle is actually 1" per side narrower then yours. my front is about an inch wider then yours. just so you know. you probably wont see a difference though.
Than you very much man. I appreciate the help.
