Big waste of time putting that intake and carb on the 87 Vic 5.0. It's got a roller cam, but it's the smallest of the production cams. And the pistons don't have valve reliefs to swap heads and cams. Rebuild the Vic motor with flat topped pistons with reliefs and a 1.609 (or as close to that as possible) Then swap cams and heads. As it is, you'll be dissappointed in the performance, even less so with that intake and carb. I used an 88 Vic motor as my first swap candidate, the 1/4 mile times were in the 16's, and that was with it topped with a Performer RPM, Holley 650 and 1.7 rockers The 289 heads to use are the C6OE's with the 54 cc chambers. The D0OE heads to look for are the ones with "351" cast in the rocker valley.They also have 8 intake bolts per side with "L" shaped coolant ports. These are the ones with bigger valves and ports. There are 302 heads with this casting number that have the 302 sized valves.
