Ranger TTB Pigeon Toed Problems
brithunsicker
TRS Banner 2012-2015
Lecompton, KS
I've got a 97 4x4 Ranger TTB with a 6 inch suspension lift on 35's. I've been having caster/camber problems lately with it. The alignment shop is telling me it is in alignment. So obviously the alignment rack is telling them it is within factory specs, and they showed me the print out of all the degrees and it shows green in all areas. But you can take the truck off the rack, drive it home and look at it and see the tires are pigeon toed (in at the top and out at the bottom). And the weird thing is that it is completely backwards from all other Fords. Mine goes pigeon toed driving forward and then becomes straight as an arrow in reverse, opposite from other lifted Fords. And the ball joints are not worn out. Anybody have any ideas on what could be wrong?
Thanks in advance!
