RustMan
- Mar 8, 2012
- 1994 Ford Range
- Automatic
I have a 94 Ranger with only 80,000 miles but it has driven me nuts by not starting at times. It was towed in 3 times and nothing could be found. After it wouldn't start in my driveway my wife went on line and found the cure which my ace mechanics including my local dealer couldn't find. Fuel pump relay!! If you turn on the key and you do not hear the fuel pump turn on, go under the hood in the fuse box and swap one relay for another and Voila, the fuel pump will work and the truck will start. My new relay cost $12.00 and since Sept.2011 the truck has started and run fine, and I now get where I'm going!! I had 3 other 94 Ford products and they have a limited computer system that won't find this flaw, but I'm not sure if the newer systems would find this. If it doesn't show on the OBD everyone just throw's up there hands.
My Ranger is a 2wd 4.0 Super Cab, I hope this helps someone.
