ranger sas problem,
fordman2010
i put a dana 30 under my 2001 ranger but my brakes wont work even though i bled all four corners what do i do?
make sure the bleeder valves are located at the top of the calipers. that would be the first thing i would check.
if the bleeders are on the bottom of the caliper then you have the calipers on the wrong side of the axle.
start at the RR tire and bleed it. then move to the LR and to the FR and finally the FL tire. it helps to have one person in the cab pumping the brakes while you watch the air escape from the lines so you dont allow air back into the lines
thanks il try it and make sure the bleeder vaves are right
