Ranger SAS no speedo
justinlovetice
so heres the situation. i have a 2001 ranger 3.0 v6 that has been converted from 4X2 to 4X4. in the process i put a transmission and transfer case from a 2000 ford ranger(5 speed still), as you know the VSS was in the rear axle in 2000 and in 2001 they changed to the OSS in the transmission. so now i have the OSS plug at the transmission with nothing to plug it into therefor i have no speedo and odometer. is there a simple fix to this like running that oss wire to the abs wire on the rear axle. or what are my options? i need to get this done ASAP. thank you.
It might be easyer to swap transfer cases that has one. Thats what i did to get my speedo again.
*post deleted due to me being dumb and reading that backwards.
After re-reading, I'd swap in a different t-case. It sucks that you just bought that one, but it would be simpler than swapping the tail pieces of the case. Besides to do that you would have to find a good case w/ a speedo hole anyway.
