I bought a 90 Ranger XLT Ext cab 4X4 4.0L pushrod motor A4LD automatic (maybe - info on this site may say it is) that I really like (I also have a 2001 Ranger regular cab XL 2.3L that won't make enough vacuum to run the brakes (really fun to drive, so I don't) that, at 230,000 miles has 2500 rpm of tach left at 100mph without scaring me - I need a track to go faster than that. R90 only has 85 mph on the speedometer and it does that easily but there's a clunk in the front axle I don't want to diagnose.
Anyway, R90 has reverse, but only when it wants, but it's so seldom I can safely say it doesn't have reverse, but, about 3 weeks ago, I needed reverse, didn't have it so I stuck one leg out the door and pushed it backward with my leg. Reverse decided to work, threw me out enough to smack me to the pavement with the door and run over me. I don't recommend this. I'm fairly anxious to fix this, but automatic transmissions haven't been a problem until now. I changed the ATF, filter, pan (with a drain plug) and gasket (in my gravel driveway, not jacked up - that much laziness is no virtue) and poured 16 oz. of Marvel Mystery Oil in it then filled it. I discovered it has a fairly large transmission cooler just behind the grill, so I poured more ATF in, to the place it said not to put in anymore. It went into reverse and let me drive around the driveway in reverse. I went to D, pulled back to the work space, tried reverse and it shot me a middle finger, hadn't engaged until shortly before it ran over me. Does it have a reverse solenoid? Something on the linkage? I hope this isn't something that has only happened to me. Has anyone fixed that? Thanks. I was born handing wrenches to my dad, who was under his latest hot rod in the early 50's (I'm old) and my first impulse is to tear it apart and find what's broken. It usually works. It's hard to ask for help, but please help me if you can.
