Dugan
Discovered that today the so called condensation in my exhaust turns to be coolant. The water is not in the oil nor is the oil in the water, but the water comes out the tail pipe. So now just pissed because other then the heads and the dent i kicked in the already shot fender, i dont know what to do with this motor. It runs strong but I leak coolant out the exhaust.
What im going to do is take off the exhaust and figure out which side is leaking then check my donor motor to see if the bad side of my current motor is the good side of the donor motor. Other then this anyone have any ideas on why this would happen? Could it just be a head gasket or could I not be that lucky. We figured out the rad was gunked with crap after we drove the truck down the road a bit and the temp shot to the L in NORMAL on the gauge. But the water in the exhaust issue happened since I bought the truck and just thought the gas from sitting for two years had contained water.
Any input or options would be awesome thanks.
