im going to be turning my 94 ranger splash 2wd into a drift truck.
im going to installing a rear end with disc brakes and a l/s with 3.73 or higher ratio.
rear brakes will only have one caliper per side with only a hydro brake connected.
the engine is a 4.0 with just over 100k miles (same as tranny)
transmission is an automatic. i do not have plans to swap it. i do plan on fabricating a better way to cycle through the gear limiter
the truck will be lowered 4r/3f inches
i will be making a cage/rollbar for the bed along with steel boxes to better distribute weight
im looking for advice on what else i should do or not do to it to make it into a fun drift vehicle
ik it wont be the best thing on the track, but thats not what im looking for.
thanks.
i will probably post pic of the truck through out the build once i start it
thanks.
