wasnt sure where to post this. my truck has been making this clicking sound. to me it sounds like its coming from the front left but its hard to tell when your driving. i thought it was wheel bearings at first because i had an issue with the spindle and the bearings kept slipping. ive since replaced the spindle and put new bearings in. it started up again and i figured they might have been bad. so i put new ones on again. 2 weeks later it started clicking.
theres no way im burning through bearings that fast... and yes ive been installing them correctly.
so then my dad suggests a u joint on the front axle shaft. i have manual hubs so my axle isnt live so it can't be that.
so that leads me to 2 possible things that i can think of.
rear driveshaft u joint or a bad hub.
how exactly do the hubs work. do the splines slide onto the shaft like a jeep or do they just lock into place. i think the latter but my dad argued with my that they were broken and all manual hubs slide onto the shaft.
it seemed like every time i re greased or replaced the wheel bearings (i greased the hub too) it would stop for a while so im leaning towards a bad hub.
also after i drive for a long distance or faster it gets progressively worse to the point it makes almost a squeaking sound instead of clicking. its intermittent and speed related. it will sometimes click for 5 minutes straight and then cut out for a few seconds and come back. i dont know what to make of it
long post i know. thanks for not quitting half way through. any suggestions to try
