ranger/bronco front axles
westtexasbaja
I need to replace my right front axle. Front diff is a Dana 35. My TTB beams are 4.5" wider each side. Does that mean these axles are from a full sized Bronco of the same year? Headed to the junk yard... The boot end of the right axle has been cut off to allow for the long travel.
Issue: on the 4x4, where the outer stub axle rides in the needle bearing inside the spindle has been "machined down" for some reason. This allows axle movement and its chewing up the washer out on the end of the spindle.
Thanks
Take some measurements and do some checking. Looks like they could be full size unless those rims have a real positive offset
