Ranger Body Swaps
ZRANGER5.0
de
1988
hi ya doin,
i just recently joined this site for some info on doing a body swap from one truck to another. so far i have an 88 ranger s/c with 5.0 HO/AODE. rest is stock from 94 stang. now that i have my 90 ranger s/c i wanna put that body on the 88 frame and do whatever mods need to be done. for instance wiring and heater box, you know the swap almost all over again. i only have the problem of taking my 90 body and putting on the 88. for the wiring harness that feeds up through floor pan from the frame. both trucks have body lifts and fairly new bushings so im not too worried about that mess. just need some extra brain power on the electrical aspect of things. all the body mounts line up exact (tape measure) everything seems to be the same only difference is the front clip. anyone got any suggestions?????? :dunno:
You didn't say why you were doing the swap...if its cause you want a newer body style, its just cosmetics, the front clip will bolt on, making it a whole lot easier...if its cause the cab is rusted or damaged, it would be easier to swap the motor into the other truck...Either way the wiring on the two trucks are different and you will have to do a V8 swap for the new truck...
SVT
