Ranger and Jeep Rims the same?
mmlaing
Ontario
Hello All,
Am I understanding that rims that fit on a jeep with fit my 09 ranger? I have the stock 225/r70/15 tires.
Thanks
Mike
Hey Mike.Some jeep rims will fit.There's a writeup in the tech section describing which jeep rims ,and others, that will fit on a rbv. hope that helps.
they are the same lug pattern but my bro had a set of jeep wheels and they wouldnt go over the front stock hub on his 85
Fyi:
If you checkout my build on my green 94, you'll see that they can be made to fit SAFELY! The center hole has to be machined out to around 2 3/4" and then use push-thru center caps.
