Ranger 96.starts but wont turn after key cylender broke.
Bussybubbz
Help. Starter turns but engine wont. No gas smell. 1996 4cyl
TagsNone
Jump to LatestUnfollow
1 - 10 of 10 Posts
[IMG alt="Bussybubbz"]https://www.fordforums.com/d2/avatars/m/210/210923.jpg?1641672498[/IMG]
Bussybubbz
·Registered
Joined 7 d ago
Discussion Starter · #1 · 7 d ago
1996 ranger. 4 cyl manual transmission. Car started and ran great until it froze outside. Then a piece of the ignition tumbler broke off. Now the starter turns but not the engine. It's not the battery. I changed the ignition tumbler that the key goes into. Same problem. All the fuses are good. The fuses are grounded. I never smell gasoline under the hood after trying to start it except for this one time when I grounded a prong on the fuel pump relay and tried to start it. That time it smelled like gas very strong. How can I tell if the ignition is engaging in the full on position or if it is only in accessory mode? The lights and radio work fine with the key turned on. Thanks.
SaveShare
Reply Quote
8
85ltdcrownvic
·Super Moderator
Joined Apr 23, 2016
#2 · 7 d ago
I’m kind of confused. You have verified that the serpentine belt isn’t moving while cranking? If the starter moves but the engine does not I would think it’s the starter not engaging the flywheel.
07 Gt Tungsten Grey
Roush (Airaid) Cai, GT500 Tb with BlowByRacing Adaptor Plate, UPR O/r X Pipe, M80's, Pypes Muffler Delete Axle Back, Sr Performance Adjustable Motor Mounts and Steeda Tri Ax Short Throw Shifter
02 Gt Mineral Grey
Steeda Sport Springs, 3.73s, Pro5.0 Short Shifter, Pypes O/r X Pipe, full 2.5 inch exhaust with M80's, 75mm Tb and C&L Plenum
87 Mercury Grand Marquis
SaveShare
Reply Quote
Like
[IMG alt="R.S.LOGAN"]https://www.fordforums.com/d2/avatars/m/53/53878.jpg?1599252889[/IMG]
R.S.LOGAN
·Super Moderator
Joined Apr 24, 2007
#3 · 6 d ago
Is the starter turning the engine but it's not firing / starting ? Is the starter turning but pinion not engaging ? " It's not the battery." what voltage on battery ?
Never, never, never give up.
SaveShare
Reply Quote
Like
Bussybubbz
·Registered
Joined 7 d ago
Discussion Starter · #4 · 3 d ago
The engine fan turns so the belt turns when the key is all the way forward but the engine doesn't start. It never floods. No gas smell.
SaveShare
Reply Quote
Bussybubbz
·Registered
Joined 7 d ago
Discussion Starter · #5 · 2 d ago
The serpentine belt turns. Need to double check battery tester. 11v but the starter is turning strong.
SaveShare
Reply Quote
R.S.LOGAN
·Super Moderator
Joined Apr 24, 2007
#6 · 2 d ago
11 v , your battery is knackered or at least needing charged and then tested
SaveShare
Reply Quote
Like
Bussybubbz
I got the ignition switch out and started the engine using it manually. The check engine light stI'll never comes on but the battery light and airbag light do when I slide the switch in the run or full on position. I will probably get a new ignition switch and try that soon. While the truck starter cranks, I saw no spark fromkl the spwrk plug wire near a ground but I pulled only 1 wire. This engine is very hard to access. I hear the gas pump come on now for about 3 seconds when I slide the ignition switch forward to near the cranking position which should indicate its in the run.position (maybe) but perhaps this switch can be cleaned up or repaired or I may just buy a new one.
