Random Engine Light Turn on
loneranger48
Washington
So this seems to be happening alot lately..if i go around a wide sweeping corner and just make a sharp corner my check engine light will come on? its weird and it also seems like i have lost a little bit of power too.The light only comes on when i turn and if i take corners slow it doesnt come on.any suggestions?:icon_confused::icon_confused:
Make a difference if turning left or right? prolly not is my guess.
IS there any codes tripped?
anyway.....look over your grounds.....cab to frame...main battery cable...engine to frame, etc.
might be that the pitch of the cab as you turn might be enough to compromise the ground somewhere. this could also act the some for vacuum lines
is your alternator belt tight?
oil is fresh and i think the belt might be loose cuz when(i know they are not built or meant the pull this kind of RPM's) i rev it up to about 5 grand the belts will squeel but thats the only time..im gonna check the grounds here soon,i just got done making sure the cab and bed were bolted down nice and tight due to the fact i have a 2 inch body lift.
Does kind of seem like it does it more often when i turn right..
