Radius arm bushings..... need help....
Either way the that particular cross member should be the same I would assume.
Ok so I changed out the old for new today.
Looks like some one had before me and used cheap bushings and only one side was done.
Hence the lack of rivets I was asking about.
As well there is no way to change the axle pivot bushing with out removing the coil spring on my truck.
So two mysteries solved, one problem fixed.
Next weekend comes the center link, tie rod ends, stabilizer bar bracket bushings ( front and rear ) and stabilizer end links ( front and rear ) as well as the axle pivot bushings then and alignment.
I'll get to the bottom of this god damn clanking if it kills me LOL !
