radius arm bushing
mudwarrior
central iowa
i have a question and its probably been asked and i may be asking in the wrong forums.im doing a sas on my ranger with bc 7 inch coils up front and im using front axle and radius arms and mounting brackets from a 78 bronco.the question is do they make bushings to correct the angle of the front axle.the steering and is pointing toward the ground.i thought about cutting the radius arms to correct the angle but if they make a bushing it would make things alot more easy.
yes they make correction bushings for the "C's " ( that is the bushing for the front of the radius arm on the axle housing )
Bronco Graveyard, Wild Horses, Summit, and many others ( even Ebay ) have them in different degrees.......
l8r, John
