- Jul 31, 2016
- Mass.
- 3.0 V6
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
I have a 2001 Mazda B3000 4X4 with its factory AM-FM CD (Single) Player. Was performing several months maintenance with the battery disconnected. The radio worked fine prior.
After completion and connecting the battery, the radio is totally inop. like it is getting no power. Worked fine before so checked the three fuses, all are good. Have a digital Multi meter and check for power and getting voltage although the readings are variable - think it's due to meter sensitivity.
Have researched the web (for hours...) to find out if there is a Re-Set button, Anti Theft Code required, etc. and find only contradictory information. The Data Tag on the radio shows it's a 1L2F-18C815-JA. Does not specifically list a SN but has a Bar Code with *DL036240* listed underneath which I assume is the SN.
Have had the battery disconnected before although not for more than a few days and all was fine after connecting it. Read through the PATS section of the manual and there's no mention of Audio issues if power is removed. Guess it's possible the radio decided to fail during the down time but want to find out if there is a reset/unlock code or process required.
Thanks to all.
Thanks to all.
