radio question
scott5640
Davenport FL
i currently have this radio
and i want to get the stock radio for a 2005...
my question is, does the plugs from the back of my current fir in the stock?
If I'm understanding you correctly, and you're referring to the harness, the answer is no. Ford has their own radio harness for their own radios. But if your remove the harness that goes into the Pioneer, the Ford wiring harness should plug right into the stock radio. Why would you want a stock radio anyway? What's wrong with the Pioneer?
i just dont like the look of it and i want the stock 1...
jays right, the stock radios wiring harness should plug right in to the other side.
Unless the harness was cut and the Pioneer harness was spliced in. Do you have a pic of the harness?
can you post a pic of the back of the stock radio(from a 2005+)
see the black plug, follow the wire down and it should go to another plug, thats the plug that plugs into the stock radio, if it not there, then you will have to go to te junkyard and get a plug for the factory deck.
the blue plug is for some type of addon for the pioneer, bluetooth, hdradio, sat radio etc.
which btw that is a nice pioneer deck, why get rid of it, it will far exeed the stock deck?
ebay but has the pics you want
http://cgi.ebay.com/ebaymotors/05-F...98QQitemZ200367117208QQptZCarQ5fAudioQ5fVideo
you mite not like the look of it but the sound quality of the pioneer is much better the stock!
there is also a hidin cross-over on the pioneer for you to tweak it to the kinda music you like! just hold you audio down for about 30secs from there you should be able to access the cross-over! if i were you i would keep that pioneer!
