Radio drawing power when off
95rangerstx4x4
I have a 95 ranger stx/splash and the factory radio is drawing power.when truck is keyed on the speakers make a thump sound.I found tht taking out the jbl system fuse under will keep it from drawing power.any suggestions on wht my problem is.thanks yall!
we need details, it sounds like you have more than just the stock setup
Well its a stock hu now but a month before this started I had a aftermarket in.all speakers are stock no amp installed.nothin rewired all just like it came from the factory
did you cut any part of the wiring harness? if you have the jbl system, did it have an amp?
No i didn't have an amp installed and I didn't cut any wires but i found a box behind the hu in the dash tht the speaker run into.I'm guessing thts the jbl system tht I didn't kno I had till I found tht fuse.but I'm thinkin thts the source of the problem
