Radiator?
AngloSaxon
Charlotte, NC
My radiator finally took a hit. The plan is to snatch one from the pull-a-part.
What other years of rangers or broncos that will fit? Will all the radiators of different engine sizes be the same?
Thanks
You'll likely come out cheaper in the long run to buy a new one... I know this from experience. Radiators.com is about the cheapest I've found, they come with a lifetime warranty- tell then you only want a year warranty and it gets a bunch of money cheaper still.
The yards wanted $100.00 for used ones that had sat on racks exposed to sunlight. In most cases they were truning from black to gray. I ended up with a new Spectra for $128.00.
a common upgrade is a 2 row radiator from an explorer with an auto.
What about getting it fixed? Theres a shop in my area that will fix a leak or replace a cracked tank, accutaly take the tanks off and clean the core out, paint the tanks and make the whole thing look new for $60 give or take a few bucks if the tanks get replaced.
I got a few of them fixed in the past. Lasted about two years or so, and ended up buying a new one. In the long run, cheaper just to buy new and be done with it.
