the radiator on a broncoII is pretty small...but it seem to have alot more place in there.
you guys know an other model , bigger, that can be easely fit in there?
look up a radiator from a, say... 1990 ranger with 4.0 a/c and an auto. Its a bit bigger than twice the stock thickness, and bolt on, only other thing you need is the lower hose from the same truck.
I have a 88 BII and I used a radiator from a 91 ford explorer with a automatic tranny. The only thing I had to do was drill one hole for the top mount and I was even able to use the stock hoses with no problems.
91-94 Explorer Radiator, Max Cooling, A/C, with automatic transmission. Check specs on it before buying to make sure it is the 2 row. There are hoses people have found to make up for the thickness that fit well, but it's really easier said than done. I am pretty sure my hoses just needed trimmed from what I remember when I swapped one in for my 2.9L. But otherwise is a direct fit. If you're an auto, might consider changing out that small fluid cooler for a better one up front while you are in there.
For
