- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
I am about to get started swapping an 84 Ranger 2.8 into an 86 that needs a motor. I want to keep the 84 Radiator and from what I can tell I will have to swap out the core support to keep it. I know that if spot welding the support on they make drill bits to remove spot welds that also make it easier to re-weld. I can get the bit no problem, but I don't have access to a welder. Can I just use a regular drill bit to drill out the spot welds and then bolt on the new support? If I can what size drill bit would I need to remove the spot welds.
Thanks!
Thanks!
