rack & pinion steering gear replacement
rangerbot
I am nut sure how the steering gear works but I have seen how to pull it on utube but it did not really show how to check if the remanufactured rack and pinion assembly has to be centred.
I know you have to lock the steering wheel so it cannot turn freely as there is a spring inside the column that gets destroyed.
So does the new rack need to be centered and how is it done.
Thanks in advance.
