RABS fuse locations
rkneeshaw
Northern Michigan
My truck didnt come with an owners manual, and I can't find one anywhere. Can someone who has one tell me where all the ABS fuses and relays are located in the fusebox in the cab and under the hood?
EDIT: And before someone says "in the fuse box in the cab or under the hood", I'm looking for the fuse # so I can pinpoint their location :)
i have them for you (thankfully i drove my truck to work! :yahoo: ) and could look at my manual and panel and Distribution Box.
on the fuse panel in the cab, they are fuses 9 and 14. Fuse 13 also is ABS, but controls PCM, Brake Lights, 4WD and Speed Control.
under the hood in the power Distribution box.....from the side towards the cab are two rows of fuses. the fifth fuses on the left AND right column are the ABS. on the right side, slot 4 is blank and the left side slot 2 is blank....
there are also a set of small diodes right behind the relays. the outer two (closest to the fender) are ABS and Rear Antilock.
i have pictures, but as i am at work, so i cannot upload photos :bawling:.
if i can...i will because they are helpful!
logged into my home computer and uploaded some photos!
Fuse Panel with Fuse 9 (10 AMP), 13 (15 AMP) and 14 (10 or 20 AMP) highlighted
Distribution box layout from the service manual.
i highlighted the places where the fuses/diodes are located.
and here's the actual distribution box where the missing fuses/diodes were.
note the large space on the right side where the space was already blank and unused. the fuse was below this space.
the diodes were the ones on the very outside and middle. not the innermost one.
sorry the pics werent better. they were the best i could get while at work.
