Quiet Reliable Fuel Pump?
rednine4
I am currently running my BII with a carbed 302 swap and using a MR Gasket (cheap) fuel pump. I got this for free and it works fine and is nice and quiet, I do think that it is pretty sketchy and I don't want it to fail on me. My carb needs 5-9 psi from the pump and I am currently using an adustable regulator to keep around 7 lbs. of pressure. What is a good make/model fuel pump that I can replace mine with before it fails and not have to worry about. I am going for Quiet and Reliable any suggestions?
I've used both the MrGasket 12S pump(35 gal/hr) and the similar Purolator pump 30 gal/hr) for years with nary a hitch. The later was on my Ranger for ten years until I sold it. The Mr Gasket has been feeding the three 2 bbl carbs on my 331 for about 4-5 years now. If you ask me, you don't have anything to worry about.
Check the Airtex website. I've used their frame mounted fuel pump for over a year. It runs 5-9psi and 30gph.
There is a 428CJ Mustang here that uses the same pump and it is fueling a 750 double pumper just fine.
Good Luck
i used the holly red fuel pump. Its expensive but reliable. Its somewhat loud tho. Id recommend it tho. Easy to install 2 wire power and ground. Runs great with a carbed 302 v8.
Anyone have any input on
a Carter 4070?...A site i frequent recommends them and i may pick one up..
