Quick spring question
JimRummy
Los Angeles, CA
Hey, I was just wondering if there is a major difference between the 2wd and 4wd coil, and leaf springs?
Basically I have the opportunity to get some 4wd leafs and coils, and was wondering if its worth it. I already have the lift blocks, so im just curious to the size difference.
The leafs are the same and i believe the coils are too. you would prolly have better luck with some explorer leafs or lift blocks and coil spacers. People also use f-150 coils but that will give you a stiffer ride.
Ah, I see. I thought that maybe since the blocks made the back a little higher, the coils mohr be a little higher to compensate. Guess not. Thanks.
I was surprised that the front coils were the same too. I was told by my dad that the front fenders were different to accommodate the bigger tires, but i haven't confirmed that yet...
