Quick Question Please Help
Buckeye Ranger
Fairfield, Ohio
Hey yall. I need to know if these tires would fit a stock rim. I have a 95 Ranger 4x4. Im pretty sure the stock rim is a 15x7? But what I need to know is would these tires fit on the stock rim... They are 32X11.50r15
They would fit, but it'd bulge a little.
15x8's would be a better choice. 15x7's would work, and I'd probably just run the 15x7's myself.
MIGHT cause a little uneven tire wear, but it'd be fine.
They should be alright, but you'll want to adjust your tire pressure, I wouldn't fill it to the max pressure listed on the sidewall. I have some old bias ply 33x12.50x15 tires on 15x8 rims on my choptop, found that to wear the tires evenly I'm only running 10-15psi.
One way to test how it's wearing is to draw a chalk line across the tread then go for a short drive down the street. If the chalk is worn out of the center but not the edges, use less air. If it's worn on the edges an not the center, you need more air.
