Quick Ford 9" lug pattern
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
Minnesota
I have a 92' ranger 2wd w/ a 7.5 axle and will be swapping a Ford 9" From a mid 70's f-250.
What's the bolt pattern on the 7.5 and whats the pattern on the 9"?
I tried to looked it up in the tech library, but I need clarification. I plan on buying wheel adapters to accomidate my Ranger rims(custom painted, don't wanna use the steel truck rims)
not sure about the 7.5 pattern but you do realize that an F250 is a 3/4ton rearend with an 8 lug pattern do you not?
There were no F250's with a 9" rearend. 9" rears came with one of three bolt patterns: 5x4.5, 5x5, & 5x5.5
Whoops. I mean an F-150. It's a 10 bolt rear end
7.5 is a 5x4.5 and the nine inch is 5x5.5 u need the axlse drilled for the stock wheels to work
Actually, my brother found some 5x5.5 to 5x4.5 hub adapters, but otherwise I would have had the axles drilled
