FFparker
I'm thinking of swapping out my 7.5 3.73s axle to an 8.8 4.10s axle. Before I do I just wanted to clear some things up
Would changing the U-joint be a good idea at this point (only have 70,xxx)?
I have read stuff about not wanted to unbalance the drive shaft so how would I make sure I don't do that when disconnecting it?
Where can I find new U-bolts?
I would be getting the 8.8 from another ranger so this should be a direct swap. I'm also adding an AAL kit while its all apart.
