question on tires size
probably will fit. i'm sure they will fit much better with a small lift. either 2-3 inch body lift or the same with front spacer/spring and rear block. and don't forget to see what gears you have in your axles. 3.08 or 3.45's and you'll be wanting to re-gear for any kind of decent performance from your 2.9, especially if it has the auto tranny behind it.
just my $.02.
ya i have no idea what gears i have ive had the truck for a month dont even have plates for the truck yet its a manuel 5speed how can i tell what gears i have
Look at the axle code on the door sticker, then go to the tech library and find that code. It will tell you your gear ratio, if its open or limited slip, etc. Alternatively, you could crawl under the truck and try to read the tag on the diff cover of the axle.
