rurouni20xx
well i have a leaking head gasket (or so i hope im losing antifreeze and you can smell it from the exhaust, no physical leaks) and am looking into getting another head installing a cam/valves/porting/shaving it for a lil more umph since i have the head off anyway. looking into the compupro stage 2 or 3 crower cam with matching lifters/springs retainers, and oversize valves/bronze guides/viton seals. the real question for you guys, how far down do you shave the head to achieve 11:1 compression? its a 92 ford ranger 2.3 8 plug head with hyd roller rockers, im keeping the hydraulic roller rocker setup. found a few headgaskets, would like to go with a .040 inch headgasket but if needbe i found a .032 compressed thickness gasket. any and all input on what i want to try and do will be greatly appreciated. also if anybody has a used head they would like to sell (sticking with the 8 plug head for use with the factory ignition system.) ill gladly look at it.
